Community Member
Is it possible to use Cisco 1721 AUX port to dial into MS-RAS?
Is it possible to use Cisco 1721 AUX port with external modem to dial into Microsoft W2k-RAS server?
Re: Is it possible to use Cisco 1721 AUX port to dial into MS-RA
Yes you can, please refer to this doc:
http://www.cisco.com/warp/public/471/mod-aux-dialout.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Community Member
Thanks for the info but I was wondering if its possible if the w2k server was directly connected to an external modem. So basically I'm trying to get my modem to handshake with the other modem which I currently have set up and can do and then talk to the W2k server after authentication. I'm constantly experiencing disconnects after modem to modem handshake completes. Any thoughts or ideas would be appreciated.
Community Member
Hello Thanks for the link. The place where I'm stuck is when the async is going through the LCP negotiation. the LCP Confreg sends but I dont' get back anything. Cisco documentation states "make sure autoselect PPP or Async mode dedicated are set but I'm actually dialing into a Microsoft RAS server. Do you know where these settings are?
*Mar 1 05:38:04.782: As65 PPP: Phase is ESTABLISHING, Active Open
*Mar 1 05:38:04.782: As65 PPP: No remote authentication for call-out
*Mar 1 05:38:04.782: As65 LCP: O CONFREQ [Closed] id 43 len 20
*Mar 1 05:38:04.782: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Mar 1 05:38:04.782: As65 LCP: MagicNumber 0x314EFEBB (0x0506314EFEBB)
*Mar 1 05:38:04.786: As65 LCP: PFC (0x0702)
*Mar 1 05:38:04.786: As65 LCP: ACFC (0x0802)
*Mar 1 05:38:06.782: As65 LCP: TIMEout: State REQsent
*Mar 1 05:38:06.782: As65 LCP: O CONFREQ [REQsent] id 44 len 20
*Mar 1 05:38:06.782: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Mar 1 05:38:06.782: As65 LCP: MagicNumber 0x314EFEBB (0x0506314EFEBB)
*Mar 1 05:38:06.782: As65 LCP: PFC (0x0702)
*Mar 1 05:38:06.782: As65 LCP: ACFC (0x0802)
*Mar 1 05:38:08.782: As65 LCP: TIMEout: State REQsent
*Mar 1 05:38:08.782: As65 LCP: O CONFREQ [REQsent] id 45 len 20
*Mar 1 05:38:08.782: As65 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Mar 1 05:38:08.782: As65 LCP: MagicNumber 0x314EFEBB (0x0506314EFEBB)
*Mar 1 05:38:08.782: As65 LCP: PFC (0x0702)
*Mar 1 05:38:08.782: As65 LCP: ACFC (0x0802)
164
