Community Member
ISDN and Dial up Network
Dear Sirs,
I have an ISDN network as the following:
Main office :
Cisco router 2821
Branches :
- Cisco router 1841
- WIC-BRI- S/T -V3
After I complete the configuration all branches working well but I can't add new branches because there is no ISDN lines available in these places just I found Telephone line (Dial up).
The problem is what I need to add in the main router  ( Hardware and configuration)  to make the main router accept the dial up calling ?
Find the attached image about the network which I need.
ISDN branches are working well only the dial up branch (PC) is not working yet.
Thank you for your help.
Hall of Fame Super Gold
Re: ISDN and Dial up Network
On the hub, you need PVDM2-xDM, where x is 12, 24 or 36 according to number of simultaneous modem calls that you want to support.
On the branches, you can use WIC-1AM that is V.92 modem.
Community Member
Dear p.bevilacqua,
Thank you for your reply.
About the PVDM2-xDM where can I install it? on motherboard inside 2811 router ? and what hub did you mean ?
Please see tha attached image it's what you mean?
In the branches I want to use the personal computer ( Win XP ) because in some branches just we have 1 computer .
Yes, on the motherboard. Hub means the central site of a network.
Please remember to rate posts clicking on the stars below.
