ISDN & Async commands
A quick one for a learner like myself.
I'm looking to configure a group-async interface which acts as a callback server, but my research seems to suggest, that a certain command "dialer-map class" is reserved for ISDN interfaces only.
Is this a fact? Or can I use it on my Async interface?
1 REPLY
Re: ISDN & Async commands
I have never heard of 'dialer map class' being restricted to only ISDN. The command applies to all types DDR connections. So the async interface should be fine.
If you using an IOS that is 'restricting' you from applying the command, then configure a dialer interface to terminate the calls
260
