ISDN call rejecting due to unknown reason
Hai all
I am trying to connect two sites using
ISDN.But the call is getting rejected.
The "debug isdn q931" message gives
" Cause i = 0x8095 - Call rejected "
The code 95 indicates call rejected due to unknown reason.Does anybody knows the
solution to solve this problem.
Regds
Sudeesh
VIP Purple
Re: ISDN call rejecting due to unknown reason
Hello Sudeesh,
this cause code usually indicates that there is a problem with the signalling on the D-channel. Can you post the configurations of your routers ?
GP
Sir
I am posting the configuration of both routers
Two things i would suggest here is to remove the dialer pool-member 2,3 from the bri interface.
interface BRI0
no dialer pool-member 2
no dialer pool-member 3
As per your config ur making use of only one dialer to the remote location so theres no need for additional 2 statements.
Also the access-list which permit the traffic by default which is binded with the dialer-list command.
So do mention access-list 1 permit any in ur routers on both the ends..
regds
VIP Purple
Hello Sudeesh,
I am not sure if this is a typo, but form your configuration it looks like both your dialer interfaces have the same IP address:
RouterA
interface Dialer1
description connection to Lawkim Thn
ip address 172.20.1.1 255.255.255.252
RouterB
interface Dialer1
Can you change one of the IP addresses to 172.20.1.2 255.255.255.252, and see if that makes a difference ?
HTH,
GP
hi Gp
I made the mistake in the attachment.In actual
configuration the ip address is 172.20.1.2 255.255.255.252 .
regds
VIP Purple
Hello Sudeesh,
can you try and change the static route to a default on both sides ?
ip route 0.0.0.0 0.0.0.0 dialer1
and remove the other static route ? I am not sure if that makes a difference, as the error message indicates that there is something wrong with the D-channel signalling, as mentioned before. Can you do a ´debug ppp authentication´ and post the output, as well as a ´show isdn status´ and post that output, too ? Also, which IOS version are you running ?
GP
Sir
The IOS of RtrA is c1700-k9sv3y-mz.122-13.bin
And the show isdn status is
grvisdn1#sh isdn stat
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 103, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=6, sapi=0, ces=1, B-chan=2, calltype=DATA
Active dsl 0 CCBs = 1
The Free Channel Mask: 0x80000001
Total Allocated ISDN CCBs = 1
At present I can't send the remote site IOS and sh isdn stat since no access to remote site.I tried the remote site with two different routers.
Initially 800 and now 1700 .Not able to connect
with both routers.
regds
What is missing in your config is PPP authentication.
Try using "ppp authentication chap" in your dialer profiles on both sides of the ISDN link.
Do let us know if the problem is solved and how.
Rgds,
Nitin Bhandarkar
I would also look into the PPP debugs - specifically ppp negotiation and ppp authentication.
Is there any filtering based on incoming ISDN number?
326
