ISDN Config Problem on 1601R
Hi all,
I need an expert advice to solve a problem with a dial-up access configuration .
I tried different configurations but the communication doesn't last more than 30 seconds .
I also issued some debug commands like :
debug ppp dialer events
debug ppp negotiation
debug ppp autentication
and so on .
In the attached file you'll find some configurations I tried and and image regarding the "show isdn status" command.
Thanks in advance
Re: ISDN Config Problem on 1601R
Your config looks fairly ok on first sight. However, you are missing an ip nat outside on config nr 3. The fact that calls are disconnected within 30s may likely be due to a ppp negotiation problem.
Could you please post the output for: deb ppp neg?
Leo
Bronze
looking at the three different configurations, a couple of questions: what are you connecting to ? The remote name is ´ciscov´, and since you have configured ´ip address negotiated´, that remote router has to give out the IP address. Is ´ciscov´ configured for that ? If so, does ´ciscov´ have the PAP or CHAP name of your local router in its database ?
You could try and use fixed IP addresses on both sides, configure each other´s username in the local database, and also configure ´ppp authentication chap pap´, that is, without the ´callin´ option.
Anyway, without knowing the exact details of your network, I have tried and merged a few things together from the three configs you posted:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
no ip directed-broadcast
ip nat inside
interface FastEthernet0/1
no ip address
shutdown
interface BRI1/0
no ip address
encapsulation ppp
ppp multilink
dialer pool-member 1
ppp autentication pap chap callin
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Dialer0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer string 7027020000
dialer remote-name ciscov
dialer-group 1
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname xxxxx
ppp chap password xxxxx
ppp pap sent-username xxxxxxxxxxxxxx password xxxx
ppp multilink
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
logging synchronous
transport input none
line aux 0
line vty 0 4
login
no scheduler allocate
end
Nethelper
107
