ISDN connection fail
Hi experts, I have an ISDN connection and tried to activate it by dial test, but the test is fail and found the following message, can anyone help?
Jun 12 08:35:09: BR1/0 DDR: Attempting to dial 0112223334445
Jun 12 08:35:09: ISDN BR1/0 Q921: User TX -> INFO sapi=0 tei=64, ns=4 nr=8
Jun 12 08:35:09: ISDN BR1/0 Q931: SETUP pd = 8 callref = 0x72
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Keypad Facility i = '0112223334445'
Jun 12 08:35:09: ISDN BR1/0 Q921: User RX <- RR sapi=0 tei=64 nr=5
Jun 12 08:35:10: ISDN BR1/0 Q921: User RX <- INFO sapi=0 tei=64, ns=8 nr=5
Jun 12 08:35:10: ISDN BR1/0 Q931: RELEASE_COMP pd = 8 callref = 0xF2
Cause i = 0x82B2 - Requested facility not subscribed
Jun 12 08:35:10: ISDN BR1/0 Q921: User TX -> RR sapi=0 tei=64 nr=9
Jun 12 08:35:10: ISDN Error: Invalid DSL (13) **ERROR**: CCBNI1_CallOriginate: Setup was rejected, cause = 50
Jun 12 08:35:10: ISDN BR1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8529
Jun 12 08:35:11: ISDN BR1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 12 08:35:11: ISDN BR1/0 Q921: User TX -> IDCKRP ri=21293 ai=64
Jun 12 08:35:12: ISDN BR1/0 Q921: User RX <- IDCKRQ ri=0 ai=127
Jun 12 08:35:12: ISDN BR1/0 Q921: User TX -> IDCKRP ri=34302 ai=64
Jun 12 08:35:39: BRI1/0: wait for isdn carrier timeout, call id=0x8529
Jun 12 08:35:39: ISDN BR1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8529, event 0x5 ces 1
Hall of Fame Super Gold
Re: ISDN connection fail
Where are you located?
Why did you set an american switch type ?
You are correct, the call test is made from the switch which is located in US.
Change switch type, it is not the correct type.
My configuration is using "basic-ni" right now, do you think the correct setting should be "basic-5ess"?
Thanks!
Or basic-net3 maybe.
754
