Webcast-Catalyst9k
isdn connections
Hi all
Can anyone confirm that when connecting isdn, the other ends, dialler or BRI interface has to be in the same subnet ?
Re: isdn connections
Hi there,
For your ISDN to connect you don't need the ip's to match. HOWEVER!! If you want them to talk to eachother, then they DO need to be on the same subnet.
Hope that helps,
LH
Please rate all posts
in addition to the other post, there is a special case where both interfaces do not need to be on the same subnet, yet still can talk to each other. This setup uses IP unnumbered addressing for the BRI (or Dialer) interfaces. Check the following link for a sample configuration:
Configuring ISDN BRI Using the ip unnumbered Command
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094a14.shtml
HTH,
GNT
Hey ,
All connenxns come up @ Layer 1 and layer 2 . It may be possible to have layer3 not up and rest working ..see the output no active calls made but isdn up
>>> sh isdn status<<<<
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE<<<<<<<
Layer 2 Status:
TEI = 97, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED<<<<
Layer 3 Status:
0 Active Layer 3 Call(s)<<<
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Kindly rate if helps --
233
