Webcast-Catalyst9k
ISDN dialin BRI interface
I would like to configure the 1812 BRI interface to accept ISDN dialin for the maintenance work.
if you could show the sample configuration, I will be grateful.
regards
Silver
Re: ISDN dialin BRI interface
Hi ,
Can you give a brief description of your current setup means which router is connected to 1812 for isdn connectivity.
example:
1812 --------- 3640
The following is the config for dialin for 1812.
1812:
usrname XXXXX password XXXX
int bri X
ip address XXXX XXXX
encapsulation ppp
isdn-switch type XXXX
isdn caller XXXX
ppp authentication chap
PPP chap password XXXX
ppp chap hostname XXXX
dialer-group 1
config)# dialer-list 1 protocol ip permit
3640 router:
username XXXX password XXXX
int bri X
encapsulation ppp
isdn switch-type XXXX
dialer string XXXX
ppp chap password
dialer-group 1
3640 dials 1812 router.
hope this helps....plz rate it..
satish
Thanks for you reply
Well, I would like to have dialin config for the ISDN dialup (connection modem to BRI interface)
1, login to router by telnet
2, login to the network
Could you check the config & debug ?
config;
aaa new-model
aaa authentication login default local
aaa authentication login dialin local
aaa authentication ppp default local
aaa authentication ppp dialin local
aaa authorization network default local
username cisco privilege 15 secret 5 $1$5B3f$5v2STaD3vTaHcdC/BCHWs1
username pppuser password 0 pppuser
interface FastEthernet0
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface BRI0
ip unnumbered FastEthernet0
encapsulation ppp
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
peer default ip address pool POOL
no cdp enable
ppp authentication chap pap
ip local pool POOL 192.168.1.2
debug;
PPP / ISDN
*Jan 23 14:06:43.347: ISDN BR0 Q921: User RX <- UI sapi=0 tei=127
*Jan 23 14:06:43.347: ISDN BR0 Q931: SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Called Party Number i = 0xA1, '21'
Plan:ISDN, Type:National
*Jan 23 14:06:43.351: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x3E calltype 1 HOST_INCOMING_CALL
*Jan 23 14:06:43.351: ISDN BR0 EVENT: host_incoming_call: call_id 0x003E, Guid = C9C7C6DA8034 bchan 0
*Jan 23 14:06:43.351: ISDN BR0 EVENT: UserIdle: callid 0x3E received ACCEPT_CALL (0x13)
*Jan 23 14:06:43.351: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
*Jan 23 14:06:43.351: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to N/A N/A
*Jan 23 14:06:43.351: BR0:1 PPP: Using dialer call direction
*Jan 23 14:06:43.351: BR0:1 PPP: Treating connection as a callin
*Jan 23 14:06:43.351: BR0:1 PPP: Session handle[CC000030] Session id[44]
*Jan 23 14:06:45.347: BR0:1 LCP: Timeout: State Listen
*Jan 23 14:06:45.347: BR0:1 PPP: Authorization required
*Jan 23 14:06:45.347: BR0:1 LCP: O CONFREQ [Listen] id 86 len 15
*Jan 23 14:06:45.347: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
*Jan 23 14:06:45.347: BR0:1 LCP: MagicNumber 0x1C669BCD (0x05061C669BCD)
*Jan 23 14:06:47.335: ISDN BR0 Q921: User RX <- UI sapi=0 tei=127
*Jan 23 14:06:47.335: ISDN BR0 Q931: SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
*Jan 23 14:06:47.363: BR0:1 LCP: Timeout: State REQsent
*Jan 23 14:06:47.363: BR0:1 LCP: O CONFREQ [REQsent] id 87 len 15
*Jan 23 14:06:47.363: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
*Jan 23 14:06:47.363: BR0:1 LCP: MagicNumber 0x1C669BCD (0x05061C669BCD)
*Jan 23 14:06:49.351: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Jan 23 14:06:49.351: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x3E calltype 1 HOST_DISCONNECT_ACK
*Jan 23 14:06:49.351: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from unknown , call lasted 6 seconds
*Jan 23 14:06:49.351: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
regards
224
