ISDN Dialing - Erratic Behaviour
keshavahp
Network Design as follows -
• Individual branches dial and establish a connection to the Central Location; in case of its primary leased line failure between the Branch and Central Location.
• Central Location dials and establishes a connection to the Data Center. in case of its primary leased line failure between the Central Location and Data Center.
• All branches are spread across the Country and have been activated with STD calling (Interstate dialing / calling).
Problem facing -
• One of the Branch with 2801 Router+2BRI S/T card + 12.4(3B) IOS dials and establishes connection to the Data Center which is located in a different state successfully.
• But this above branch does not dials a test call to its Central Location; which is again located in a different state. (Point to be noted: "STD Dialing is activated on this Branch, that's why it is able to make a call to the Data Center successfully, but fails making a call to the Central Location *01202775453*").
Can any one please HELP me to rectify this issue.
Please find the attached Debug q931 & q921 output of the Branch router when dailed *01202775453* and fails.
Keshav
7 Replies 7
spremkumar
Level 9
Level 9
Have you checked the configurations of both the central location which requries to accept the call and the other location which is already accepting the call from the branch ?
But as per the error message this is something to do with your central location's telco settings which you need to contact either BSNL/MTNL to get it resilved.
C1 - Bearer capability not implemented
The network cannot provide the bearer capability that the user requests.
Contact the telco to troubleshoot further.
http://cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
regds
Hello Mr. Prem,
Thanks for responding!
I have checked with BSNL at Central Location - they claim that all calls are allowed on the PRI link of Central Location and no such restrictions have been configured.
Keshav
dongdongliu
hi,
are you sure that the switch-type and spid number are both set right?
Hello Mr. Liu,
Here in India Telco's will not use the SPID no#, hence SPID's are not configured.
ISDN Switch type is configured with the right one *basic-net3*.
Can this be a IOS Bug?
hi Keshava
could you post any configuration?
hi Keshava
It seems the L2 is well(from router to isdn switch), but, what`s about L3 info?
could you show us "show dialer/isdn status & debug dialer" info?
thank you
regards
dongdong
yxsjwsb
Hey, I'd use the pri debugger tool (free - pippinsoftware.com ) to keep up with that failures. It may reveal that only certain B chans are affected.
