10-18-2005 10:05 AM
i have a isdn connection which is used to connect to a terminal server fom my office to a branch office.I have a cisco 3640 router in my office and cisco 1603 at the brnch office site.
This isdn connection gets disconnected in every 1 or 2 hours even when the connection is not idle. i have set idle timeout to a higher value....When it is disconneted it doesnt dial from my side when i ping from my side..But it is pinged from other site it gets connected...
pls pls help me...i amout of answer
10-18-2005 10:28 AM
Check first the idle timeout on both sites + the keep alive settings.
Peter
10-20-2005 12:12 AM
i have put the idle timeout as 10800 and no keepalive set
10-18-2005 10:55 AM
in addition to what Peter says, be aware that the idle-timeout is based on outgoing traffic by default. From what you are describing it appears that the remote site is initializing the connection. Can you post the configurations of your routers, as well as the IOS version (show version) from both routers ? This just to check for ISDN-related bugs, of which there are many...
GP
10-20-2005 12:47 AM
Hi peter,
This are the configuration in my office :
version 12.0
service timestamps debug uptime
service timestamps log datetime localtime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
isdn switch-type basic-net3
chat-script mod ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
chat-script offhook "" "ATH1" OK \c
interface Ethernet0/0
ip address 172.16.50.1 255.255.255.0
no ip directed-broadcast
interface Ethernet0/1
no ip address
shutdown
interface BRI1/0
ip address 172.16.200.25 255.255.255.248
encapsulation ppp
dialer idle-timeout 10800
dialer map ip 172.16.200.27 name PCR 97712445
dialer load-threshold 3 outbound
dialer-group 1
no snmp trap link-status
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
ip local pool ippool 172.16.50.80 172.16.50.100
ip classless
ip route 172.16.3.0 255.255.255.0 BRI1/0
ip route 172.16.3.0 255.255.255.0 172.16.201.27
ip http server
ip http authentication local
logging 172.16.50.10
access-list 5 permit 172.16.100.0 0.0.0.255
access-list 10 permit 172.16.0.0 0.0.255.255
access-list 101 deny eigrp any any
access-list 101 permit ip any any
access-list 115 permit ip host 172.16.50.181 172.16.100.0 0.0.0.255
access-list 115 permit ip host 172.16.50.180 172.16.100.0 0.0.0.255
access-list 115 permit ip host 172.16.1.189 172.16.3.0 0.0.0.255
access-list 115 permit ip host 172.16.1.55 172.16.3.0 0.0.0.255
access-list 190 permit ip any 172.16.100.0 0.0.0.255
access-list 190 permit icmp any 172.16.100.0 0.0.0.255
access-list 190 permit ip 172.16.100.0 0.0.0.255 any
access-list 190 permit icmp 172.16.100.0 0.0.0.255 any
dialer-list 1 protocol ip list 115
route-map GM permit 10
match ip address 115
set interface BRI1/0
set ip next-hop 172.16.200.27
l
end
and this is the output for sh version at my site :
IOS (tm) 3600 Software (C3640-I-M), Version 12.0(4)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 29-Apr-99 14:28 by kpma
Image text-base: 0x600088F0, data-base: 0x60726000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 1 week, 3 days, 23 hours, 6 minutes
System restarted by reload
System image file is "flash:aaa0435.bin"
cisco 3640 (R4700) processor (revision 0x00) with 28672K/4096K bytes of memory.
Processor board ID 14827567
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
4 ISDN Basic Rate interface(s)
16 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Regrds
nikki
10-20-2005 12:50 AM
Hi Peter
This are the configs at the remote office :
Current configuration:
version 11.2
service timestamps log uptime
interface Ethernet0
ip address 172.16.100.1 255.255.255.0
ip nat inside
interface BRI0
ip address 172.16.200.27 255.255.255.248
ip access-group 102 in
encapsulation ppp
dialer map ip 172.16.200.25 name PCN broadcast 5234564
dialer-group 1
hold-queue 75 in
ip classless
ip route 172.16.50.0 255.255.255.0 172.16.200.25
ip route 172.16.50.0 255.255.255.0 172.16.200.25 250
access-list 101 permit ip host 172.16.100.40 172.16.1.0 0.0.0.255
access-list 101 permit ip host 172.16.100.50 172.16.1.0 0.0.0.255
access-list 115 permit ip any host 172.16.50.180
access-list 115 permit ip any host 172.16.50.181
set interface BRI0
set ip next-hop 172.16.200.25
dialer-list 1 protocol ip list 101
banner motd ^C 4
^C
l
end
this is output of sh version command :
IOS (tm) 1600 Software (C1600-OY-L), Version 11.2(16)P, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Mon 19-Oct-98 12:59 by pwade
Image text-base: 0x0200544C, data-base: 0x0237ED30
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Router uptime is 2 weeks, 4 days, 22 hours, 37 minutes
System restarted by power-on
System image file is "c1600-oy-l.112-16.P", booted via flash
cisco 1603 (68360) processor (revision C) with 7680K/512K bytes of memory.
Processor board ID 13604538, with hardware revision 00000001
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface(s)
1 serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
8K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
10-20-2005 01:53 AM
I see you have only one customer and on the local site ppp multilink enabled and not on the remote site, enable this also on the remote site. The idle timeout you are using right now is very high, around 600 will be enough.
Let me here your results.
10-22-2005 10:54 AM
i have enable ppp on other site also but still i am not able dial from my side, once disconnected it will not dial even when i ping from my side but if pinged from the remote office it will dial and establish a connection.
i am not able to dial from my side after it is disconnected.i dont find any reason not to dial out and it was working fine till 1 week before.
when i ping and dial from office the isdn led at the remote office shows an activity but doesnt establish a connection.
10-23-2005 12:26 PM
Okay, for ease of understanding where "here" and "there" and my side and the other side are at, it might be useful to give a name to each of the routers, such as, "MainOffice" and "RemoteOffice". I found it easier when looking at the two configs to do that myself. I assume the main office has the 3600 and the remote office is running the IOS 11.2. A couple of things to think about here:
1. When at the main office, I am looking for triggering events to establish a call. Looking at your routing table I have this:
I assume that any attempt to try to get to network 172.16.3.x will fire up a connection to either int bri1/0 or the IP addr that corresponds to the far end.
I then go looking for that distant network on the remote router. Here is what I deduced from the routing table I cannot see:
ip address 172.16.100.0
ip address 172.16.200.24
ip address 172.16.50.0
Okay, where exactly are we hiding the 172.16.3.x network? From what I can see, there is no network for 172.16.3.x in either routing tables for the mainor remote office.
My guess is that you had a working config one week ago and nobody saved it with the "write mem" or "copy run start" command. You also might want to have your ISDN switch type set on both routers (they may be different). Also, you need to recheck all of your access lists on both sides that tie into your dialer group commands and make sure the from/to networks make sense. Right now, they do not. For example, you have this on your remote office:
Show me where the network 172.16.1.x exists in the main office?
pw
10-24-2005 07:48 AM
A lot of good catches pw. You have to wonder about the Nat statement on the Remote Ethernet interface if it should be there or if there are more config lines missing.
There is also an access list applied to the remote BRI0 interface but no access list in the configuration.
I think access list 101 should be a mirror image of 115 at the host.
Mike
10-24-2005 11:56 AM
I wondered about the NAT statement and I just drew blanks. I just wasn't sure where to go with that, so I didn't. You are correct about the access group expression applied without a corresponding access list. Depending upon how old the IOS is, different behaviors will ensue. Older versions of the IOS will assume what you really *meant* to say, which was to drop all packets (silly you, why would you apply an access group without a corresponding access list). In later versions of the code train, the software engineers figured you had already whacked the access list, but forgot to drop the access group expression from the interface. The net effect would be to allow all packets. Guys like Rick Burts or Terry Slattery would probably have enough history working with the IOS to know exactly where that line of demarcation was in the IOS. 11.2 may be in the ballpark...
pw
