Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ISDN logging
IS thr any method to log all data of ISDN status for billing verification ? or calls verification
1 REPLY
Re: ISDN logging
The simplest method would be collecting the syslog from the router which can help you to ascertain the time being used by the circuit.
you will get the details of connection establishment and the disconnection time with the remote peer on the logs which can be used to manually identify the usage time.
regds
118
