Community Member
ISDN on load balanced vpdn
I have an issue with vpdn :
I 2 LNS routers that I terminate l2tp vpdn sessions on them using load balance.
For analog dialup everything is fine , but for ISDN i need that the 2 sessions terminate on the same LNS , but I dont know how to control it as sometimes the first B session terminate on one LNS and the other B session terminate on the other which cause it not to work.
Can anyone advise ?
Re: ISDN on load balanced vpdn
can you post the configs of your LNS routers ? That in order to see how your load-balancing is configured, and to make appropriate recommendations...
GNT
Community Member
The LNS config is :
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
lcp renegotiation on-mismatch
l2tp tunnel password 7 01121F054D1B0201
interface Virtual-Template1
ip unnumbered FastEthernet0/0
peer default ip address pool dialup
ppp authentication pap
ppp multilink
The load balance is done through the radius server by DNIS . It returns to the NAS the IPs of the 2 LNS and the NAS terminate the tunnels on both LNS by round robin.
Community Member
Hello , can anyone advise me regarding this ?
Thanks in advance
121
