ISDN PRI problem
naive.naive
When the dialing router initiate to the receiving router, it gives an error message below at the receiving router end:
*Jan 13 09:09:41.522: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00E0
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Calling Party Number i = 0x0183, '03771820900'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '2030'
*Jan 13 09:09:41.526: ISDN Se1/0:15 EVENT: process_rxstate: ces/callid 1/0x93 calltype 1 CALL_INCOMING
*Jan 13 09:09:41.526: ISDN Se1/0:15 EVENT: call_incoming: call_id 0x0093, Guid = 005D3B29426A
*Jan 13 09:09:41.526: ISDN Se1/0:29: Incoming call rejected, unbindable
*Jan 13 09:09:41.526: ISDN Se1/0:15 **ERROR**: call_incoming: DIALER ERROR 0x1: b channel 29 call id 0x93
*Jan 13 09:09:41.530: ISDN Se1/0:15 EVENT: process_rxstate: ces/callid 1/0x93 calltype 1 CALL_CLEARED
*Jan 13 09:09:41.546: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80E0
Cause i = 0x8095 - Call rejected
Whats does that means??
10 Replies 10
most likely, there is a problem with the dialer interface bound to a physicall interface. Check if the physical interfaces have the command 'dialer pool-member' configured, and the corresponding dialer interfaces the 'dialer pool', as in this example:
interface BRI0/0
dialer pool-member 1
interface Dialer1
dialer pool 1
GP
The receiving router dialer config as below.(the router will be accepting calls from 2 remote site)
interface Serial1/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
ppp multilink
interface Dialer1
ip address 1.188.8.2 255.255.255.248
encapsulation ppp
dialer pool 1
dialer idle-timeout 60
dialer load-threshold 1 outbound
dialer-group 1
ppp authentication chap
interface Dialer2
encapsulation ppp
dialer pool 1
dialer-group 1
on your dialer interfaces, you need to specify the remote name of the device calling in, e.g.:
interface Dialer1
ip address 1.x.x.x.255.255.248
encapsulation ppp
dialer pool 1
dialer remote-name Branch_Router
dialer-group 1
Also, make sure that the local username and password are configured:
username Branch_Router password 0 cisco
On the branch router, you need to do the same, with the username being the name of the central router. The passwords need to match, and are case- sensitive:
So, if your central office router´s hostname is ´Central_Router´, the following needs to be configured on the branch router:
Branch_Router
username Central_Router password 0 cisco
HTH,
GP
i've tried, it's the same error..
i'm just wondering is there any error on my dialer config?? coz its sharing same dialer pool ??
at second glance, I would say yes: the IP addresses on both dialer interfaces are identical, you might want to change those...
HTH,
GP
have tried to change the IP address..its the same result..
but i've tried something else..
i removed dialer pool 1 and dialer-group 1 in the int dialer 2..and it managed to dialed in but cannot be bind to a dialer...
any idea what is configured wrongly??
have you configured the ´dialer remote-name´ on the dialer interfaces ?
GP
yup..i've entered the dialer remote name..but still the same...
anything that i configured wrongly??
nbhandarkar
What's missing from your config is the "ppp authentication chap" command on the D-channel of your PRI ie. Serial 1/0:15.
Then add the "dialer remote-name " on the dialer interfaces.
That should solve your problem.
Pls rate this post if it helps.
nbhandarker,
thank you..
you are my hero..
you solved my problem..
but how can i rate it??
