ISDN Problem
suresharja
Hi All,
I have set branch offices connected to central office using leased lines and ISDN lines as backup.The dialer interfaces configured in braches to dial to central office are dialing to central office when leased line goes down but not able to exchange the routing table and not even able to ping to central office.can you through some light why ? From branch office when I try to ping to central office dailer interface IP address, ISDN line is getting connected( show isdn active is showing the connection) but not pinging.
suresh
6 Replies 6
balajitvk
Level 4
Level 4
Hi Suresh,
Verify that the backup interface IP network is included in the routing protocol configuration in both sides and also chk whether the backup interfac e ip on both sides are in the same subnet.
This is the mistake we use to face when the backup link is established but no routing information is transmitted across the backup link
Rate if it does,
Rgs
Hi Balaji,
I have verified the configuration and the problem is Central Office router not able to map the dialer interfaces to Physical BRI interfaces.It is found out when I see " Show interface DialerX ". But when I see "SHOW ISDN ACTIVE" router showing the active connections.
How to solve this problem.
Suresh
Hi suresh,
If you are finding the mapping between dialer interface to BRI is not happening, then chk whether the dialer pool is configured in the dialer interface and whether that particular BRi interface is configured as a memeber of that dialer pool.
Just try debug dialer command and see whether it will indicate the following for an outbound call:
*Mar 1 07:20:45.676: Di15: Cannot place call, no dialer pool set
if this is case, Configure the dialer pool command on the dialer interface.
Or If the physical interface is not associated with any pool, the debug message on the calling router will be the same as in the case where no more physical interfaces are available, causing the fast idle timer to trigger
*Mar 1 11:54:14.937: Di15: No free dialer - starting fast idle timer
Configure the dialer pool-member command on the physical interface to associate it to a dialer pool
If still it not solves ur problem, could u post ur config. so that we can also deal better.
Rate if it does,
Rgs
madhur_malik
Hi Suresh,
As you have created seperate dialers for each branch. It seems that ISDN Calls are not getting bounded with respective dialers.
a) You can add "dialer caller XXX" command in all the interface where XXX will be the remote ISDN number which will be dialing to Central Router.
b) Else try configuring authentication in physical interface at Central Router such as BRI0 in case of BRI or S0:15 in case of PRI).
If still it doesn't solve your problem, i would request to put your router configuration.
Madhur
Hope this will give u an idea.....
sample configuration
Remote Router
hostname remote
username HO password secret1
isdn switch-type basic-net3
interface Ethernet 0
ip address 131.x.x.x.255.255.0
interface BRI 0
encapsulation PPP
ppp authentication chap
dialer idle-timeout 300
dialer map IP 131.x.x.2 name HO
dialer-group 1
ip route 131.108.x.x.x.0.0 131.108.157.2
ip route 0.0.0.0 0.x.x.108.157.2
dialer-list 1 protocol ip permit
Main Router
hostname HO
username xxx password xxx
interface BRI 0
encapsulation PPP
dialer map IP 131.x.x.1 name remote
dialer-group 1
ip route 131.x.x.x.x.255.0 131.108.157.1
regards
Babu
kianaun
Suresh,
Can you post up the config file for troubleshooting purposes?
My assumption is:
- Main is using PRI and leased line.
- Remote will dial-in when lease-line is down through ISDN.
- Routing,dialing number all will need to be taken care off.
Please post config to verify further.
thks,
ken
