Webcast-Catalyst9k
ISDN
I am configuring aaa authorization network for ppp authorization but I don't want to enter username password in ACS for all routers dialing in as we have more than 100 routers dialing in to our central hub router.
I tried configuring without dialer remote-name on hub router for dialer profiles but it doesn't work also I can't put same remote-name for all the remote routers under different dialer interfaces.
Is their any workaround
Re: ISDN
can you post the configs of your main site and one of the hub routers ? Basically, you would need a dialer interface for each remote site...
GNT
Re: ISDN
Yes i have dialer interface for each remote site but I want authorization of ppp by ACS for which as explained I need to enter authorization name for each router and I can't use same remote-name under different dialer interfaces.
My objective is to have single username for all the routers for ppp authorization.
107
