Silver
Issue with dialup connection
Kindly help me ,as line and group range command not accepted in 3845 router .
What will be reasion
Re: Issue with dialup connection
The particular feature set of your ios code may not have the support for these kinda commands better check out on which feature set/version its supported and better to have them on your router.
regds
Bronze
Hi Shivlu,
Do you even have an internal modem card in this 3845 for it to be able to show you tty lines towards the bottom of the config ? Unless and until you have a modem card, and the router shows you line , there is no way you would be able to define group range under group async interface.
Thanks and Regards,
~Zulfiqar
121
