Community Member
Kerberos Contraint Delegation and Cisco SSL VPN
Guys, I am evaluating the Cisco SSL VPN solution against another vendor.
I see that the Cisco SSL VPN solution does not support Kerberos Constraint Delegation. Can someone shed some light on this and tell me what the heck I will be losing if I use an SSL VPN solution which does not support Kerberos Constraint Delegation? Also, please tell me in which example or scenario Microsoft/Active Directory applications should suffer if such Kerberos Constraint Delegation is not supported.
Thanks!
Silver
Re: Kerberos Contraint Delegation and Cisco SSL VPN
Your vpn connection simply won't come up
Community Member
Not sure if I understand your answer.
I talked to a Cisco SE on this and he told me that Cisco SSL VPN does not support Kerberos Constraint Delegation with protocol transition.
237
