L2TP VPDN with Radius
Hi Everyone,
I've Configured L2TP server with Radius Authentication, client is client initiated L2TP , config in the attachment, authentication with radius okay but the router won't pass the attribute especially the ip address (when the router in debug mode it receive the attribute from radius, so i'm very sure the radius is working ) . I've several remote access connection, so the aaa is not using default instead I define per "WORD" that's telco.
here is the configuration
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authentication ppp telco group radius
aaa authorization exec telco group radius
aaa authorization network telco group radius
aaa authorization configuration telco group radius
aaa accounting network telco start-stop group radius
vpdn-group 1
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
interface Loopback0
ip address 1.1.1.x.x.255.255
interface Tunnel0
ip unnumbered Serial1/0.86
tunnel source 192.168.12.90
tunnel destination 202.x.x.1
interface Serial1/0.86 point-to-point
description none
bandwidth 56
ip address 192.168.12.90 255.255.255.252
no cdp enable
frame-relay interface-dlci 86
interface Virtual-Template1
ip unnumbered Loopback0
no peer default ip address
vpdn authorization telco
ppp authentication chap telco
ip route 10.225.1.0 255.255.255.252 10.225.0.5
ip route 10.128.25.0 255.255.255.0 Tunnel0
radius-server attribute 8 include-in-access-req
radius-server host 10.224.1.32 auth-port 1812 acct-port 1813 key xxx
Re: L2TP VPDN with Radius
I think you should take a look at "radius-server configure-nas" and http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/secur_c/scprt2/scrad.htm
1007
