Large Scale Dialout Using TACACS+
I have big number of dialout connections . That why i am trying to use the concept of "Large Scale Dialout Using TACACS+". The problem that i have is that, in arround 800 situations i should dialout to standalone systems ( Windows PC's) that can be accessed remotly through an analog modem. All these systems have the same IP address. Can i use the concept of "Large Scale Dialout Using TACACS+" to send NAT Informations also, i.e, is it possible to send the Tel, nr. and routing informations an then the NAT command to translate the ip address in the dialer command which is not the real address of the end system to the real one.
Thanks for replaying
Ali
Silver
Re: Large Scale Dialout Using TACACS+
Hi Ali,
Yes You can use. We can change some configurations attaribute and achieve.
Also there is concept of " aaa route download "
By that you can send routing informations.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008794b.html#21944
Dharmesh Purohit
See on :
Dharmesh thanks for replaying,
Do you mean we can change some attributes and be able to send a nat translation also . Can you please give me more details.
Thx
Ali
146
