10-30-2006 01:35 AM
I have two ISDN routers, both having the BRI ports.
On my router, ports are configured as follows:
interface BRI0
bandwidth 128
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
no cdp enable
interface BRI1
bandwidth 128
no ip address
encapsulation ppp
no cdp enable
interface Dialer1
bandwidth 128
ip address <ip> <Netmask>
encapsulation ppp
dialer pool 1
dialer remote-name <name>
dialer idle-timeout 30
dialer string <number>
dialer caller <number>
dialer load-threshold 1 either
dialer-group 1
no cdp enable
Remote is configured as follows:
interface BRI0
bandwidth 128
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI1
bandwidth 128
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
bandwidth 128
encapsulation ppp
dialer pool 1
dialer-group 1
ppp multilink
no cdp enable
What happens is that all of the four B-channels are used, even if I have set bandwidth 128, so if I dial to this remote site I can't dial to the other remote sites I have.
How can I correct this behaviour, i.e. have my remote site that takes no more than 2 B channels?
Ciao
10-30-2006 02:28 AM
Hi ,
You have configured a single dialer and have binded the BRI with the dialer and with this config , you cannot connect to two locations.
Use two dialer and bind each BRI with each dialer and use it to connect to two locations.
For a single location means , change the dialer load threshold to 150 ( 150/255 ) load so that the four channels are not triggered immediately rather than getting triggered based on load condition.
Pls let me know if your requirement was something else
regards
vanesh k
10-30-2006 05:23 AM
This was only an example. I have 20 different dialers.
What I need is not to have all four channel triggered after a while, but to have no more than two channels triggered, whatever bandwidth requirement I have.
Ciao
10-30-2006 05:12 AM
use load threshold command.
10-30-2006 06:16 AM
In the original post from Francesco it is clear that both dialer intefaces already do specify the load threshold command.
I note in the original post that the first router does not include ppp multilink in its config while the remote router does specify ppp multilink. I am not clear whether the difference is real or is a result of inconsistent cut and paste by Francesco. I would think it would be problematic if the configs were really inconsistent in this matter.
I also note that there is no authentication on the BRI or on the Dialer interfaces. I have seen situations where not specifying authentication will cause one connection to be made for inbound traffic and a different connection to be made for outbound traffic. I suggest configuring ppp authentication (could be PAP or could be CHAP) and see if that changes the behavior.
Rick
10-30-2006 08:55 AM
Rick,
I'll try tomorrow your suggestions. There are no ppp multilink on one side, because when I had ppp multilink on both sides I had the problem that after a while, router stopped making dial out, i.e. the debug showed interesting traffic, but this didn't cause a dialup anymore.
Somebody suggested me to remove ppp multilink from my side, and this effectively worked, since I hadn't experienced that problem anymore.
Ciao
ciccio4242
11-02-2006 12:40 AM
Rick,
no, putting ppp authentication on BRI interface does not work.
Any ideas?
Ciao
11-02-2006 01:54 AM
If your requirement is only to have two channels triggered , then associate each BRI with a dialer , so that you have a max of 2 channels . But in case if you want multiple dialers to use a single BRI , then go fo dialer rotary group.
pls let us know if you requirement was diff
regards
vanesh k
11-02-2006 06:33 AM
network.king,
I need to have more dialers than BRI's, so I'll deal with dialer rotary groups. but can U please explain me how they work, and what's the difference with or without them?
Thanks a lot
Ciao
11-07-2006 08:02 PM
If you make just one of the BRI interfaces part of dialer pool-member 1 then the dialer will only be able to use that BRI.
hope that helps,
Andres
