loading heavy huge???? ....................................................
tareqrebhi
Dears ,
what is the zise nubmer in MB?
Bytes-In= 1734273658
i am ISP and only have 1 E1 2MB capacity .... how this huge number is coming?
TARADSL-01#sh vpdn tunnel packets remote-name BAS1-WDSIR TARLNS
L2TP Tunnel Information Total tunnels 6 sessions 31
LocID Pkts-In Pkts-Out Bytes-In Bytes-Out
187 80012466 104907434 1734273658 290998723
TARADSL-01#sh vpdn session packets username umalrimah@jaber.com
L2TP Session Information Total tunnels 6 sessions 32
LocID RemID TunID Pkts-In Pkts-Out Bytes-In Bytes-Out
49022 61685 187 27379 40592 2844040 50039650
%No active L2F tunnels.
thank you for help.
7 Replies 7
Kevin Dorrell
Level 10
Level 10
Your capacity is 2 MB per second. That huge number is the total number of bytes since the route router was switched on, or since the counters were manually reset.
Kevin Dorrell
Luxembourg
Kevin, I was to say the same, but doing the math, the average packet size comes to be 21, that is kind of smallish to be sane. Perhaps the VPDN keepalives are driving the figure down.
Kevin,
Congratulations on your CCIE!
Best regards,
Dandy :)
Thank you Dandy!
Didn't noticed that... Congrats!
Thanks Paolo!
v1inc3ntn
Is this on you external port?
What is your bytes out count???
