Mapping async console ports to cables
I have a 2620 with an async card (async32a) that is terminated to a patch panel with cable labled 1-32
My config shows something like this..
ip host indunda 2054 172.19.221.194
ip host gunter 2053 172.19.221.194
ip host alkazar 2042 172.19.221.194
I assume 20xx assigns a port/cable?
How can I map 20xx to the cables?
----Mike
1 REPLY
Re: Mapping async console ports to cables
With the following command:
ip host 20xx
.. "20xx" assigns a "line number".
The following documents make reference to the command, and may be helpful:
http://www.cisco.com/en/US/docs/ios/12_0/dial/configuration/guide/dcrtelnt.pdf
http://www.cisco.com/application/pdf/paws/10318/mod-aux-exec.pdf
e.g.:
Since my Aux port is on line 5, I would use:
ip host modem 2005
... based on the output in the attached file.
293
