br
Community Member
Modem/ISDN dialin and TCP/IP forward
Dear all,
I have to configure a Cisco 3620 router to accept any calls which are
coming in via a PRI interface. The data shall then be sent via TCP/IP
to any host.
One TCP/IP connection per call is required. The TCP/IP connection shall
be closed if the line goes down and vice-versa.
Depending on the incoming MSN (or dialled number) a different TCP/IP
host and port shall be used.
The ISDN dial in uses X.31 case A (X.25 over ISDN B-Channel) and modem
uses V.22 bis MNP.
The router has following cards installed:
NM-1FEPRI2CE1-B/U
NM-30DM
I need some hints in order to find the right documentation or examples. I don't
know the name of this "TCP/IP forward" or the specific IOS features
required.
ANY help greatly appreciated.
Best regards,
Bernhard Roth
1 REPLY
Silver
Re: Modem/ISDN dialin and TCP/IP forward
303
