Webcast-Catalyst9k
Multilink PPP over Ethernet
Hi to all!
It is possible to run MLPPP over Ethernet dot1q subinterfaces?
I fact, 2 PPPoE sessions on Multilink.
On the customer site I have a 1841 with 2 ADSL WICs.
This 2 PVC's are terminated on the 7600 on 2 VLANs..
Thanks and regards,
Thomas
Silver
Re: Multilink PPP over Ethernet
It is not possible to run MLPPP over Ethernet dot1q subinterfaces.
PPPoE does not support multilink PPP.
thanks for post.
What are the best solution to achieve a load-balancing? I see only CEF load-balancing as solution...
Any other idea?
Thanks and regards,
Thomas
If you are looking to loadbalnce the wan links its MLPPP.
In LAN you can use etherchannel.
1821
