NAT 877 mutilpe devices
I have a Cisco 877 DSL Router. My connection has two static IP addresses. Can I set up NAT on each Public IP address to two devices on MY LAN using the 877?
Thanking you in advance
  • Remote Access
VIP Purple
Re: NAT 877 mutilpe devices
are you talking about two internal IP addresses being able to use two public IP addresses ?
Something like:
ip nat inside source static 10.10.10.1 212.136.1.1
ip nat inside source static 10.10.10.2 212.136.1.2
This would map each of your internal addresses to one of the public addresses.
As an alternative, you could put both public addresses in a pool:
ip nat pool PUBLIC 212.136.1.1 212.136.1.2 netmask 255.255.255.252
ip nat inside source list 1 pool PUBLIC
access-list 1 permit host 10.10.10.1
access-list 1 permit host 10.10.10.2
Is that what you are looking for ?
GP
thnaks for the help.
MY DSL router has a single DSL interface, which is picking up the first available IP address assigned to the site.
I know how to set up NAT for a single interface i.e. I have one Public IP address going to internal address no problem.
DO I need to do anything special when one Interface has two addresses?
The example above makes sense is it as simple as that?
Purple
You certainly can.. Try this:
interface fastethernet
ip nat inside
interface atm.
ip nat outside
Hope that helps - pls rate the post if it does.
Paresh.
Purple
It is indeed as simple as that. As long as the ISP is routing both of those addresses to your link, the above will work.
Paresh.
118
