NAT Problem with Remote Access?
My office runs a small business server with a Cisco 1811 in front. I need to access ports 80 and 443 from the outside so I used a static NAT for the server IP. I also setup IPSec VPN on it. When I remote in, I can access anything on the network except for the server which is NAT'ed. If I remove the NAT, I can access the server through the VPN. Any idea why this is happening? What part of the config would you need to see to better assist in resolution?
1 REPLY
Re: NAT Problem with Remote Access?
maybe "below" is needed
access-l 100 deny ip host (server_ip)(vpn_peer_ip) (netmask)
access_l 100 per ip (server_ip) any
ip nat inside source list 100 pool nat_pool
ip nat pool nat_pool (server_ip)
95
