Webcast-Catalyst9k
Need a basic config for RAS device
Hello all,
I've been assigned a project to update our rapidly aging dialup solution and I have the following assets:
A 2821 router with 1 HWIC-1CE1T1-PRI card
A T1 PRI line
I can figure out configuring IP addresses and such, but what I really need help with is just a basic config that will allow this device to pick up calls like a modem.  As of yet, I can get it to pick up the line, but with no modem negotiating noises and such.
Here is my config as it stands:
Router#
*Aug 19 22:00:20.219: %SYS-5-CONFIG_I: Configured from console by consolesh run
Building configuration...
Current configuration : 2898 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
card type t1 0 0
logging message-counter syslog
no aaa new-model
no network-clock-participate wic 0
modem-pool test
pool-range 0/322 0/345
called-number XXXXXXX max-conn 24
modem country v12 usa
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
no dspfarm
archive
log config
  hidekeys
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
description XXXXXXX pri
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation ppp
isdn switch-type primary-5ess
isdn protocol-emulate network
isdn incoming-voice modem 56
interface Async0/322
no ip address
encapsulation ppp
interface Async0/323
no ip address
encapsulation ppp
interface Async0/324
no ip address
encapsulation ppp
interface Async0/325
no ip address
encapsulation ppp
interface Async0/326
no ip address
encapsulation ppp
interface Async0/327
no ip address
encapsulation ppp
interface Async0/328
no ip address
encapsulation ppp
interface Async0/329
no ip address
encapsulation ppp
interface Async0/330
no ip address
encapsulation ppp
interface Async0/331
no ip address
encapsulation ppp
interface Async0/332
no ip address
encapsulation ppp
interface Async0/333
no ip address
encapsulation ppp
interface Async0/334
no ip address
encapsulation ppp
interface Async0/335
no ip address
encapsulation ppp
interface Async0/336
no ip address
encapsulation ppp
interface Async0/337
no ip address
encapsulation ppp
interface Async0/338
no ip address
encapsulation ppp
interface Async0/339
no ip address
encapsulation ppp
interface Async0/340
no ip address
encapsulation ppp
interface Async0/341
no ip address
encapsulation ppp
interface Async0/342
no ip address
encapsulation ppp
interface Async0/343
no ip address
encapsulation ppp
interface Async0/344
no ip address
encapsulation ppp
interface Async0/345
no ip address
encapsulation ppp
interface Group-Async1
physical-layer async
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
no peer default ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 0/322 0/345
modem autoconfigure discovery
transport input all
autoselect ppp
line vty 0 4
login
scheduler allocate 20000 1000
end
I pieced together this config with trial and error, as well as using lots of older ASA5000 configs as a guideline, but it's high time I get some real help with this.  I have rudimentary knowledge about Cisco routers, so any links, pointers, best practices, etc. would be awesome.  Thanks!
Everyone's tags (3)
568
