Need ppp dailup to 2600 with NM-8AM
Router is 2600 with 12.3 IOS
I can't get my PPP sessions that are dialing in to use the defined radius server. Sessions connect, but don't authenticate. All this will be used for is emergency dialin.
What am I missing here?
doing a sho radius stats shows zero packets being exchanged between radius server and router.
thanks
aaa new-model
aaa group server radius radservers
server 192.168.99.49 auth-port 1645 acct-port 1646
aaa authentication login no_radius local enable
aaa authentication ppp default group radius group radservers
aaa authorization network default if-authenticated group radservers
aaa session-id common
ip subnet-zero
ip cef
ip domain name xxx.xxx.com
ip name-server 192.168.99.75
ip name-server 10.122.20.10
async-bootp dns-server 192.168.99.75 10.122.20.10
async-bootp nbns-server 192.168.99.49 10.192.20.10
interface Loopback0
ip address 192.168.98.1 255.255.255.0
interface Ethernet0/0
ip address 192.168.99.12 255.255.255.0
half-duplex
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
no ip route-cache cef
no ip route-cache
ip tcp header-compression passive
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address pool pool0
ppp authentication pap
ip local pool pool0 192.168.98.2 192.168.98.100
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.99.1
ip radius source-interface Ethernet0/0
logging trap debugging
logging 192.168.99.15
access-list 66 deny any
access-list 101 deny udp any any eq netbios-ns
access-list 101 deny udp any any eq netbios-dgm
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
snmp-server enable traps tty
radius-server timeout 1
radius-server key changeme
line con 0
logging synchronous
line 33 40
modem Dialin
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
1 REPLY
Re: Need ppp dailup to 2600 with NM-8AM
updated config
fyi, if I have Winxp do a "pop-up" window after modem connects, I don't get ppp characters, but am prompted for username..
This makes no sense since I am forcing the connection to PPP in the Async group.
aaa new-model
aaa authentication login no_radius enable
aaa authentication ppp dialins group radius group radservers
ip subnet-zero
ip cef
ip domain name bigdomain.com
interface Loopback0
half-duplex
encapsulation ppp
no ip route-cache
dialer in-band
dialer-group 1
async mode dedicated
ppp authentication pap chap ms-chap ms-chap-v2 callin dialins
no ip http server
ip classless
radius-server timeout 30
radius-server key cisco
line con 0
logging synchronous
line 33 40
modem Dialin
transport input all
autoselect ppp
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login authentication no_radius
254
