need recommendation for dial-up router and module
I need to setup a dial-up solution for our remote users to connect to.
What router and network module would be the most efficient to support one PRI (23 users max).
I was thinking about a 1760V, 1-MFT-T1 and DSPs. Is there a more appropriate solution?
Re: need recommendation for dial-up router and module
hi
Can you revert what kinda connectivity will be used by the remote users to get connected to the central site ??
for more info on supported DSP modules and the firmware required to have the DSP modules do find this link..
http://cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920f2.html
regds
Users will just be using built-in microsoft dial-up PPP client.
-Boris
138
