10-10-2008 10:18 AM
Will NM 16AM work on 3825 modular router ?Cisco advisor lists only NM 16AM-V2 module there .Is ther any IOS support the old async module ?
Solved! Go to Solution.
10-12-2008 06:45 PM
Madhu,
It is my understanding that the NM-16AM Module is not supported on the 3825. So, there is no IOS Version that will support this module.
Refer the below URL for details on the NM-16AM Module and the supported platform/minimum release.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800a93f2.shtml
Also, the NM-16AM is End Of Sale/End of Life and the last date of support is 1 year from today, Oct 13, 2009. Please refer the below URL for details.
http://www.cisco.com/en/US/products/hw/modules/ps2797/prod_eol_notice09186a008020460d.html
For the 3825, you have to go with NM-16AM-V2 module.
Arul
** Please rate all helpful posts **
10-12-2008 06:45 PM
Madhu,
Arul
