Webcast-Catalyst9k
Opening ports for ACT on model 1841
I am trying to open up a port to allow net users to sync a ACT database. When I make changes to the firewall and then applyu the changes I get a connection lost error. SDM lost connection to router because of a communication error. Router freezes up, no internet access and I have to power-cycle.
Bronze
Re: Opening ports for ACT on model 1841
when you say ACT, does that mean Symantec ACT! ? What changes are you making, and which firewall do you have ?
Nethelper
Depends on what changes yopu made to the firewall. Sounds like you applied restrictions to the interface where SDM was coming in, thereby locking SDM out.
Anyway: ACT sharing is the same as NETBIOS share management, I would recommend you use a VPN solution for that, since punching a NETBIOS hole allows anyone on the inetrnet to mount the drive, and anyone else to monitor the unencrypted NETBIOS stream.
Better to look into the VPN capabilities of the 1841.
135
