out-of-band management using WAC-AM-1 card
HI
I am trying to configure cisco 2811 router which has WIC-AM-1 card installed. I want to connect and configure this router using PSTN line terminated onto router. I am looking for only remote management and not backup solutuon. Please help.
Amol
1 REPLY
Re: out-of-band management using WAC-AM-1 card
This is what we use. We have a ACS server that hands out our dialback number per user or if it can't contact the TACACS server it will use the local username/password. Works like a champ. It will give you a 192.168.51.x address you telnet to 192.168.51.1. We also have 2 octopus cable to reverse telent to other devices.
aaa group server tacacs+ TACACSServers
server 10.x.x.x !
aaa authentication login default local-case
aaa authentication login RemoteAdmin group TACACSServers local-case
aaa authentication enable default enable group TACACSServers
aaa authentication ppp RemoteAdmin group TACACSServers local
aaa authentication dot1x default group RadiusServers
aaa authorization config-commands
aaa authorization exec RemoteAdmin group TACACSServers local
aaa authorization commands 1 RemoteAdmin group TACACSServers local
aaa authorization commands 15 RemoteAdmin group TACACSServers local
aaa authorization network RemoteAdmin group TACACSServers local
aaa accounting exec default start-stop group TACACSServers
aaa accounting exec RemoteAdmin start-stop group TACACSServers
aaa accounting commands 1 default stop-only group TACACSServers
aaa accounting commands 1 RemoteAdmin stop-only group TACACSServers
aaa accounting commands 15 default stop-only group TACACSServers
aaa accounting commands 15 RemoteAdmin stop-only group TACACSServers
aaa accounting network default start-stop group tacacs+
aaa accounting network RemoteAdmin start-stop group TACACSServers
aaa accounting connection default start-stop group TACACSServers
aaa accounting connection RemoteAdmin start-stop group TACACSServers
aaa accounting system default start-stop group TACACSServers
ip dhcp excluded-address 192.168.51.1
ip dhcp pool RemoteAdmin
network 192.168.51.0 255.255.255.0
ip host CON1 2033 223.223.223.1
ip host CON2 2034 223.223.223.1
ip host CON3 2035 223.223.223.1
ip host CON4 2036 223.223.223.1
ip host CON5 2037 223.223.223.1
ip host CON6 2038 223.223.223.1
ip host CON7 2039 223.223.223.1
ip host CON8 2040 223.223.223.1
username mikedesk callback-dialstring 1xxxxxxxxxx password 7 blah
interface Loopback192
ip address 192.168.51.1 255.255.255.0
interface Loopback223
ip address 223.223.223.1 255.255.255.255
interface Async1
ip unnumbered Loopback192
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer in-band
dialer callback-secure
dialer-group 1
async mode dedicated
peer default ip address dhcp-pool RemoteAdmin
ppp callback accept
ppp authentication chap callin RemoteAdmin
ppp authorization RemoteAdmin
ip tacacs source-interface FastEthernet0/0
ip radius source-interface FastEthernet0/0
dialer-list 1 protocol ip permit
tacacs-server host 10.x.x.x port 49 key xxx
tacacs-server directed-request
tacacs-server key xxx
line 1
exec-timeout 5 0
modem InOut
modem autoconfigure discovery
transport input telnet
transport output telnet
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line 33 48
line aux 0
line vty 0 4
password xxx
logging synchronous
login authentication RemoteAdmin
line vty 5 15
logging synchronous
201
