PPP DIAL / CAS / NAS Problem using AAA :(
vijay sanwal
Hi All ,
I am facing a strange problem with PPP dial-up using AAA with tacacs for authentication. This setup is already working on 1 router but when i am configuring same setup on different router its not working . Pls find attached file for all details.
lgijssel
Level 9
Level 9
Understanding that you are using the same adresses for the tacacs server, are you also using the same ip adress for the router?
I suppose that this is not the case but you are trying to add a second router to the network?
If so, looking at the logs, it could be that the second router has not been added as a NAS in your Tacacs server database. Hence Tacacs does not "trust" this 2nd host and refuses to authenticate for it.
regards,
Leo
