PPP double dial problem with BRI
I have two routers, A and B. When router A call router B the isdn call is setup, and I can ping both router.
However I don't understand why router B systematically recall router A.
so when I execute the command : show isdn active, my two B channel are active.
I have not configure ppp multlink, also callback is not configured too, and there is not much trafic because LAN interface are no connected. How can I avoid the second router to call me.
thanks
Re: PPP double dial problem with BRI
Is you dialer load threshold set to a low # on RouterB? Please post the relevant config.
--Sundar
Bronze
Hi Kaine,
If you run "debug dialer" and "debug dialer packet" on B, you will know why its dialing out back towards A.
Thanks and Regards,
~Zulfiqar
I really don't understand what happening, it's not the first time I configure ISDN with DDR and I have some experience in the field.
When router_A call router_B (or inversely when B call A) the ping works only when both channel are UP. Each router use a different channel to talk with the remote router. When one of the channel is down (example BRI0:2) the ping stop working.
From router_A (192.168.199.2) when I execute : ping 192.168.199.1, the "echo request" bring up the channel BRI0:1, and continue to use this channel
On router_B (192.168.199.1) the debug dialer show that router_B bring up the channel BRI0:2 to send "echo-reply".
the first ping suceed with 20% only, and the link take too many time to bring up (time to bring up the twoo channel).
I have compare with different configuration, and I can't see where I could made an mistake.
thank in advance for your help
Bronze
I am not sure if this is related to your problem, but check your CHAP configurations: your router A has hostname RT, yet you are sending
ppp chap hostname A19
while A19 is the name of router B.
Try and change the chap statement on router A to:
ppp chap hostname RT
and on router B to:
and see if that makes a difference...
Nethelper
124
