PPP Multinlink on both ends?
Is it necessary to have the ppp multilink command configured on both ends of an ISDN link? Will it function if it is only implemented on the remote end and not the hub side?
1 ACCEPTED SOLUTION
Re: PPP Multinlink on both ends?
AFAIK you need to have them enabled on both the ends.
regds
Yes, you must configure on both routers.
regds
122
