Webcast-Catalyst9k
PPPoA connections associated with a VRF using a Radius Server
We have a PE (Cisco 7600) with several ADSL-CPEs connected by PPPoA. These PPPoA connections are authenticated/authorizared by an Radius-Server (Cisco Secure
ACS v4.1) running on a Windows machine.
So, these PPPoA connections are Virtual-Access cloned from a Virtual-Template
We want the Radius to associate these virtual-access with a vrf, I mean, each ADSL-CPE has its own user in radius and its Virtual-access will be asociated
with its vrf depending of the user.
We succesfully authenticate the CPEs and even the radius inserts static routes associated in a per-user basis but the vrf association fails
In the configuration of the user in radius (Cisco IOS/PIX 6.x RADIUS Attributes) we have the following:
lcp:interface-config=ip vrf forwarding PROBA
lcp:interface-config=ip unnumbered loopback1
ip:route=vrf PROBA 69.51.218.0 255.255.255.0 10.81.18.136
ip:route=vrf VPN-ToIP 10.151.218.0 255.255.255.0 10.112.2.2
This is the configuration of the PE
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login consola none
aaa authentication enable default group tacacs+ enable
aaa authentication ppp CPEs-ADSL-PPPoA local group radius
aaa authorization exec default if-authenticated
aaa authorization network CPEs-ADSL-PPPoA group radius none
aaa session-id common
ip radius source-interface Loopback0
radius-server attribute 44 include-in-access-req
radius-server host 69.50.2.135 auth-port 1812 acct-port 1813 key <removed>
radius-server vsa send accounting
radius-server vsa send authentication
vc-class atm ADSL-Class-ToIP
vbr-nrt 2000 2000 32
inarp 1
tx-ring-limit 3
no ilmi manage
oam-pvc manage 5
oam retry 4 4 5
encapsulation aal5mux ppp Virtual-Template112
interface Virtual-Template112
bandwidth 1800
ip unnumbered Loopback1
logging event link-status
load-interval 30
no peer default ip address
ppp authentication chap CPEs-ADSL-PPPoA
ppp authorization CPEs-ADSL-PPPoA
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
service-policy output Encolado-ADSL-ToIP
interface ATM1/0/0.238 multipoint
description PRS2-218A ADSL CPE
no ip mroute-cache
logging event subif-link-status
no atm enable-ilmi-trap
pvc 0/238
class-vc ADSL-Class-ToIP
oam-pvc manage
You can see the output of a debug radius in the attached file
any idea?? What we ar doing wrong??
Silver
Re: PPPoA connections associated with a VRF using a Radius Serve
This is something I have seen as well and we assumed this was because of this reason -
The framed IP address is returned to the PE Router first and then the VRF, so when the VRF is tagged to the interface, the IP is knocked off and hence the user doesnt connect. I am sure when troubleshooting if you dont return the VRF, I am sure it must be working fine.
So the thing to be done is the IP address is re-negotiated after the VRF is returned. The standard configuration we do on the RADIUS for this setup is as follows -
Service-Type = Framed,
Framed-Protocol = PPP,
Cisco-AVpair = "lcp:interface-config=ip vrf forwarding VRF-NAME\nip address negotiated",
Framed-IP-Address = 10.10.10.5
Let me know if this solves your issue
First of all thanks a lot for your help.
I am afraid your suggestion did not solve our issue.
It seems the router does not understand "lcp:interface-config"
Silver
Can I suggest the following -
Remove this attribute lcp:interface-config=ip unnumbered loopback1
and use
lcp:interface-config=ip address negotiated
I think it's the same suggestion as before.
Anyway I've tried and it does not work
thanks
385
