PPPoA sessions stuck in LCP_NEGOTIATION
Can someone help on this DSL dail(BT DataStream) problem?
bellow is info from PE(Cisco 10k). Always stuck in LCP_NEGOTIATION. PV and VC built ok I believe. SP also checked Line is OK.
dsl-PE#ping atm int atm 3/0/0.9 9 32
Sending 5, 53-byte end-to-end OAM echoes, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/24 ms
dsl-PE#sh atm pvc 9/32 | b 3/0/0
ATM3/0/0.9: VCD: 6535, VPI: 9, VCI: 32
VBR-NRT, PeakRate: 574 (1354 cps), Average Rate: 574 (1354 cps)
Burst Cells: 50
CDVT: 140.0 Usecs, High Watermark: 288, Low Watermark: 240
AAL5-MUX(AutoPPP), etype:0x9, Flags: 0x20000024, VCmode: 0x0, Encapsize: 4
Channel Weight: 238
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM Loopback status: OAM Disabled
OAM VC Status: Not Managed
ILMI VC status: Not Managed
InARP DISABLED
InPkts: 1622863, OutPkts: 1547901, InBytes: 31142841, OutBytes: 29630537
InPRoc: 1224593, OutPRoc: 1559608, Broadcasts: 0
InFast: 92913, OutFast: 0
InPktDrops: 0, OutPktDrops: 0
Out CLP=1 Pkts: 0
OAM cells received: 2632
F5 InEndloop: 2632, F5 InSegloop: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 2652
F5 OutEndloop: 2652, F5 OutSegloop: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
DBS enabled.
VC Auto Creation Enabled: local
AutoVC Idle Timeout: 300 second(s), minimum rate: 0 kbps
PPPoA Current State = LCP_NEGOTIATION
PPPoA Latest Event = PPP Msg
PPPoA Latest Error = None
PPPoA Session ID = 19564
PPPoA Handle = 0x1F060897, SSS Handle = 0x02030D94
Switch Handle = 0xF5020F7A, PPP Handle = 0x87060B6C
AAA Unique ID = 0x0430CBDD, AIE Handle = 0xD20105C2
attached is debug info from CPE:
It seemed PPP authentication issue, but Radius check also OK.
Thanks for any advices!
1 REPLY
Hall of Fame Super Gold
Re: PPPoA sessions stuck in LCP_NEGOTIATION
hi,
It seems to me user is terminating connection, probably a cisco router that is trying to authenticate the 10k, in that it doesn't succeed.
340
