09-28-2017 10:41 PM - edited 03-12-2019 04:35 AM
I had a config working great on my 2811, so I thought it should work on a 2821 . Below is the config
Router#sh run
Building configuration...
Current configuration : 1858 bytes
! Last configuration change at 04:51:34 UTC Mon Sep 25 2017
version 15.1
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
memory-size iomem 25
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.172.0.1
ip dhcp excluded-address 192.172.0.10
ip dhcp pool Lab-Network
network 192.172.0.0 255.255.255.224
default-router 192.172.0.1
dns-server 8.8.8.8
domain-name Herman
ip dhcp update dns
vpdn enable
license udi pid CISCO2811 sn xxxxxxxxxxxxxxxx
interface FastEthernet0/0
description WAN Interface
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet0/0.1
encapsulation dot1Q 201
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
description LAN Interface
ip address 192.172.0.1 255.255.255.224
ip nat inside
ip virtual-reassembly in
duplex full
speed 100
no cdp enable
interface Dialer1
description WAN Dialer
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxxx
ppp ipcp dns request accept
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 192.172.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line 1/0 1/31
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
I copied it line by line, but I'm not able to establish a connection with the Centurylink ONT on the 2821. I forgot how I was able to establish a pppoe client on the fa0/0.1...so I believe that is the problem..below is the config for the 2821
Router#sh run
Current configuration : 1626 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
dns-server 8.8.8.8
domain-name Herman
ip dhcp update dns
vpdn enable
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable
interface GigabitEthernet0/0.1
no snmp trap link-status
pppoe enable
pppoe max-sessions 10
interface GigabitEthernet0/1
ip nat inside
duplex full
speed auto
interface GigabitEthernet1/0
ip address pool Lab-Network
interface Dialer1
ip mtu 1492
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap password 0 xxxxxxxxxxxxx
ip classless
no ip http server
control-plane
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
login
end
Solved! Go to Solution.
09-29-2017 11:28 PM
do you have a service contract ? If so, download the 12.4-15T.17 Advanced Security pack, below is the image name:
c2800nm-advsecurityk9-mz.124-15.T17.bin
09-29-2017 12:33 AM
09-29-2017 08:06 AM
09-29-2017 08:51 AM
are you running 12.4(T) or later ? Upgrade to a 15.x version if possible. PPPoE clients on subinterfaces need 12.4(T) or later...
09-29-2017 10:48 AM
09-29-2017 10:51 AM
Is that a T release ? Post the output of show version...
09-29-2017 06:29 PM
09-29-2017 11:28 PM
09-29-2017 01:10 AM
in addition to the other post, I think you also need to add 'dialer-group 1' to the dialer interface and 'dialer-list 1 protocol ip permit' globally...
