pppoe issue
I have a 7200 series router and i wana terminate pppoe cleint thru wireless and i have 30 remote site connecting thru sdh 2 mb link with 2811 at the remote site. 2811 is pppoe client so i cant terminate remote wireless client directlt coming to 2811 directly. what i wan know is is it possible that my traffic come to 2811 and then i bridge all traffic to 7200 series router installed at central location. if yes any body send me the command reffernce for this thanks
1 REPLY
Silver
Re: pppoe issue
The user must use the fully qualified domain name (FQDN) of the resource.
Manually specify the domain name information in the Windows PC TCP/IP properties. This may
be the only feasible option for a NAS with a large Windows 95 or 98 client base. Use bootp
and DHCP to obtain this information after IPCP negotiation is complete.
The Windows client sends a DHCP inform packet to the NAS, which then sends back the domain
name information. The DHCP functionality can either be on the NAS itself or an external
DHCP server. Currently only Windows 2000 and XP clients support sending DHCP inform. Use
the Microsoft website to verify this.
So to support this is appears you would have to setup dhcp on the router as opposed to
just having a local pool configured.
So something like this:
ip dhcp pool pppoe-pool
network x.x.x.x x.x.x.x
dns-server y.y.y.y
domain-name xxx
lease infinite
update arp
int virtual-tempplate xx
peer default ip address dhcp-pool pppoe-pool
With dhcp, don't forget to exlcude any ip addresses you don't want.
W1MS-8.4-3745-A(config)#ip dhcp ex
W1MS-8.4-3745-A(config)#ip dhcp excluded-address ?
A.B.C.D Low IP address
W1MS-8.4-3745-A(config)#ip dhcp excluded-address 1.1.1.1 ?
A.B.C.D High IP address
under the
virtual-template if the end device is requesting the dns information.
int virtual-template xx
ppp ipcp dns x.x.x.x
IF ip nat outside is not correctly configured then pppoe users unable to ping the internet .
102
