PPPoE on HWIC-4ESW?
2800 running with 12.4(4)T1 with HWIC-4ESW module. Can one define PPPoE
on a switchport interface? Ie:
interface FastEthernet0/1/0
pppoe enable
pppoe-client dial-pool-number 2
no routing dynamic
interface Dialer1
bandwidth 5000
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxx password 7 xxxxx
Hank
Re: PPPoE on HWIC-4ESW?
hi
the info available in CCO states that many of the features arent tested on this new module.
It goes on like this "Many features are not supported or tested on these interfaces, including Hot Standby Router Protocol (HSRP), Point-to-Point Protocol over Ethernet (PPPOE) termination, Layer 2 Tunneling Protocol Version 3 (L2TPv3) termination, MAC address assignment, Layer 3 QoS, and others. You should carefully test any desired feature and solution prior to deploying it"
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd8016c026.shtml
regds
It works with Vlans:
switchport access vlan 10
no routing dynamic
interface Vlan10
ip address 10.10.0.1 255.255.255.0
ip nat outside
pppoe enable
-Hank
Hi Hank,
Could you please elaborate on your working config as I am having trouble duplicating your results - would be hugely appreciated.
Paul
PPPoE on HWIC-4ESW?
am trying this configuration on 1941 + HWIC-4ESW.
But it does not recognize the pppoe command !
router.xxxx.com(config)#int vlan 10
router.xxxx.com(config-if)#pppoe enable
% Invalid input detected at '^' marker.
anyone was able to make it ?
am trying this on PT (before deploy)
regards,
Zied.
Hall of Fame Super Gold
Cisco may now have coded to block that, as it was never stated supported.
Use a layer 3 interface, not VLAN interface.
Do you mean I'll have to use one of the Gpbs interfaces on the router ?
If yes that would be a big waste (Gbps on PPPoE ADSL)
I was wondering if I can, "any how" get PPPoE in one port from the HWIC-4ESW.
Can you tell me if this would work ?
Create a subinterface gigabitEthernet 0/0.1 and trunk it to one fastethernet from the HWIC-4ESW
after that configure a pppoe client on GE 0/0.1
I'll give it a try and come back to tell.
679
