PPPoE with LAC/LNS infrastructure problem
I'm trying to set up connection using PPPoE within the LAC and LNS infrastructure. See below:
pppoe client ----- LAC ------- LNS
radius radius
OK. My client is authenticated and logged via pppoe but I can't see any tunnel infromation on LAC as well as on LNS...
As I assume this connection should work in following way: client wants to connect so he chooses username/pass ppp/ppp and the LAC sees that this client can connect so he forward that message to LNS via L2TP tunnel. LNS gives a permission and get back to LAC. And finally the client get access.
As I wrote client can login but I can't see any L2TP tunnels....
Configurations in next posts.
Could you please help me? So I'm sitting in front of this for 3 days and I can't go further...
P.S.
LAC#sh vpdn session
%No active L2F tunnels
%No active L2TP tunnels
%No active PPTP tunnels
PPPoE Session Information Total tunnels 1 sessions 1
Uniq ID PPPoE RemMAC Port VT VA State
SID LocMAC VA-st
8 8 000b.5d9b.1a77 Fa0/1 1 Vi1.1 PTA
0012.0148.f5e1 UP
BTW I can't ping LNS from my client (Win XP)...But I can ping client from LNS. Is it only wrongly set routing, but I don't think so...
Oooops I almost forgot: Client's IP is e.g. 192.168.2.9, so the client get IP from LAC's dhcp pool.
Re: PPPoE with LAC/LNS infrastructure problem
LAC:
version 12.3
hostname LAC
boot-start-marker
boot-end-marker
enable secret xxxx
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip dhcp excluded-address 192.168.2.1
ip dhcp pool pppoe
network 192.168.2.0 255.255.255.0
dns-server 192.168.2.1
lease 0 0 10
ip cef
ip ips po max-events 100
vpdn enable
vpdn ip udp ignore checksum
vpdn-group 1
request-dialin
protocol l2tp
initiate-to ip 192.168.1.2
local name LAC
no l2tp tunnel authentication
vpdn-group 2
accept-dialin
protocol pppoe
virtual-template 1
aaa new-model
aaa group server radius test
server 10.1.1.2 auth-port 1812 acct-port 1813
aaa authentication login default local group test
aaa authorization network default local group test
aaa accounting network default start-stop group test
aaa session-id common
no ftp-server write-enable
username LAC password 0 cisco
username ppp password 0 ppp
username cisco privilege 15 password 0 cisco
username LNS password 0 cisco
interface Loopback0
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0
description LINK_TO_LNS
duplex auto
speed auto
interface FastEthernet0/1
description LINK_TO_CLIENT/RADIUS
ip address 10.1.1.1 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
pppoe enable
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
interface Virtual-Template1
mtu 1492
ip unnumbered FastEthernet0/1
peer default ip address dhcp-pool pppoe
ppp authentication chap
ip classless
ip http server
no ip http secure-server
radius-server host 10.1.1.2 auth-port 1812 acct-port 1813
radius-server deadtime 10
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
line con 0
password cisco
line aux 0
line vty 0 4
password cisco
end
LNS:
version 12.3
hostname LNS
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
server 156.x.x.2 auth-port 1812 acct-port 1813
aaa authentication ppp default group test
aaa authorization exec default local group test
aaa authorization network default group test
ip subnet-zero
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp pool pppoe
network 192.168.1.0 255.255.255.0
dns-server 192.168.1.1
lease 0 0 10
ip cef
ip ids po max-events 100
vpdn enable
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname LAC
local name LNS
lcp renegotiation on-mismatch
interface Loopback0
ip address 10.2.2.254 255.255.255.0
interface BRI0
no ip address
shutdown
description LINK_TO_LAC
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no cdp enable
interface FastEthernet1
switchport access vlan 10
no ip address
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
shutdown
mtu 1492
interface Vlan10
ip address 156.x.x.1 255.255.255.0
interface Vlan1
no ip address
ip local pool L2TP 100.0.0.1 100.0.0.100
ip classless
no ip http server
radius-server host 1.1.1.2 auth-port 1812 acct-port 1813
ip route 10.1.1.0 255.255.255.0 FastEthernet 0
control-plane
line con 0
password cisco
line aux 0
line vty 0 4
password cisco
end
Silver
Are you sure that this pppoe session forwarded to the LNS? As it looks the session terminated on the LAC (the IP address got from your LAC's pool also proves that). I have similar setup here at the lab and working fine.
In my setup example.com domain forwarded to LNS where it get authenticated through radius.
LAC:
vpdn enable
vpdn multihop
vpdn logging
vpdn logging local
vpdn logging user
vpdn history failure table-size 50
vpdn search-order domain
vpdn-group 1
request-dialin
protocol l2tp
domain example.hu
initiate-to ip
local name whatever
vpdn-group 2
description Local ADSL testing
accept-dialin
protocol pppoe
virtual-template 1
LNS:
vpdn-group 2
description TestADSL
accept-dialin
protocol l2tp
virtual-template 2
terminate-from hostname whatever
local name testgw
lcp renegotiation always
On more important thing is the pppoe client connected to the LAC through a vlan.
LAC:
interface FastEthernet0/0.15
description PPPoE for ADSL testing
encapsulation dot1Q 15
pppoe enable
Of course the appropriate username/password should be configured on both sides to authenticate each other.
Good luck!
Krisztian
450
