05-20-2006 12:10 PM
I am trying to figure out how to get my router to initiate a PPPoE connection to my ADSL modem which was provided by my ISP.
RouterE0/1-->modem-->internet
For some reason it doesnt connect.
I get this (with debug ppp auth and dialer on):
00:48:18: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
00:48:18: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
00:48:18: Vi1 DDR: Dialer statechange to up
00:48:18: Vi1 PPP: Treating connection as a callout
00:48:18: Vi1 PPP: Authorization NOT required
00:48:18: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
00:48:18: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Says something about authorization not required???
Anyone have any advice that you could please help me with?
05-22-2006 12:41 AM
make sure that your authentication statement looks like this:
ppp authentication pap chap callin
ppp chap hostname USER
ppp chap password PASSWORD
ppp pap sent-username USER password PASSWORD
If you have that configured correctly, can you post the configuration of your router ?
GNT
07-19-2007 04:14 AM
hi,
i had the same problem for about 2 days and the best way i thought i couold solve it was to use the SDM and configure the router. I did just this and now my connectivity tests are succesfull but i cannot connect to the internet form my workstation through the router(cisco 1841).
Maybe you too should try that .
Thanks.
