Community Member
PPTP > LAN>WAN
tried to tighten security by turning on the FW and applying ACL's, everything works fine, with the exception of any LAN to WAN pptp connections they will not connect - any help would be great - and thanks
1 REPLY
Re: PPTP > LAN>WAN
Probably you forgot permit GRE protocol in your ACL.
144
