Community Member
PRI to BRI using dialer pool-member 1
I am facing some typical problem in dialer-pool 1 command.
We are having PRI line at one location and at another location we are having BRI line. As usuval BRI to PRI dialup is used as a backup to serial leased line.
PRI configuration is
interface serial 1/1:15
ip unnumbered loopback 0
ip address loopback 0 172.24.10.1 255.255.255.0
and dialer configured is
dialer 1
dialer-pool 1
encap ppp
dialer caller 2717823
Static routes are :
ip route Remote_Network Serial 0/0
ip route Remote_Network Dialer 1 100
Remote router configuration is
bri 1
dialer pool 1
dialer 0 ( as abckup up to serial link )
ip addrss 172.24.10.2 255.255.255.0
dialer string 253698
ip route Network_A serial 0
ip router Network_A dialer 0 100
In this configuration ISDN call is established and also authenticated but traffic is not routed.
But when I give command in main router's dialer one.
immedialetly routing starts.
My query is when I have made dialer 1 as a member of dialer pool 1. it should pick up ip addrss of Serial1/1:15 that is nothing but loopback 0. why a separate command is required in dialer one ?
Thanx in advance
1 ACCEPTED SOLUTION
Community Member
Re: PRI to BRI using dialer pool-member 1
As well you shouldn't even give any ip address to PRI interface
It does not work like that. Pool membership is only used to determine from which physical interface a B-channel will be used by the dialer. You always have to assign an ip address to the dialer or otherwise ip processing will use this interface.
Leo
Community Member
203
