Primary and Secondary tunnels
I am currently working with a remote office tunnel setup and I have a question about setting up primary and secondary tunnels. I have two seperate internet connects to the main office that each have a tunnels pointing back to the remote office. How do I configure the tunnels so that my primary tunnel will always be used unless it is down?
1 ACCEPTED SOLUTION
Re: Primary and Secondary tunnels
You can do it a couple of different ways, using 'backup int' command or using a floatic stating route with a higher admin distance via the backup tunnel.
int t1
ip add 10.1.1.1 255.255.255.252
backup interface tunnel2
int t2
ip add 10.2.2.1 255.255.255.252
(or)
ip route 'remote NET' 10.1.1.2
ip route 'remote NET' 10.2.2.2 250
Pls. rate all helpful posts.
HTH,
Sundar
1 REPLY
int t1
int t2
(or)
HTH,
Sundar
149
