Webcast-Catalyst9k
Problem in 5300 access server
i ve two access servers of the same model cisco 5300 series and modems that are connected with these access servers are mica modems. on one access server when clients request (using 56k modems) they can connect with 45 to 52kbps on normal dialup which is satisfactory but when the same user connecting through the other access server then it connects with 22 to 33.3 kbps. pls tell me what changes should i make to fix this problem.
VIP Purple
Re: Problem in 5300 access server
are both AS5300s configured in the same way, and do they have the same firmware (show modem version) ? If possible, can you post the configs of both access servers ?
GP
yes both have the sanme configuration. sorry i cant paste configuration here because that this is ISP and hackers would extract useful info from that.
in these senario's what we usually do?
VIP Purple
can you verify that both servers have the exact same modem version firmware (show modem version) ?
GP
yes both have the same modem version.
216
