Problem in calling BRI from PRI
I am having problem in calling BRI from PRI. I am getting below message while debugging. Also note that calling from BRI to PRI is successful.
Mar 2 23:38:22: ISDN BR0/0 Q931: RX <- SETUP pd = 8 callref = 0x04
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '1726601501'
Plan:ISDN, Type:National
*Mar 2 23:38:22: ISDN BR0/0:1: Incoming call rejected, unbindable
*Mar 2 23:38:22: ISDN BR0/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1: b channel 0, call id 0x15E
*Mar 2 23:38:22: ISDN BR0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x84
Cause i = 0x8095 - Call rejected
Pls help me.
Anis
9229109694
Hall of Fame Super Gold
Re: Problem in calling BRI from PRI
Please send BRI router config and what router / card it is.
Pls find the config attachment of BRI end.
Card is Cisco WIC 1B-S/T
Silver
Hi ,
Pease configure username and password on both routers ...in privileged mode.
cheers :)
satish
Dear Satish,
Can u pls give me an example for this config.
As Enable Secret is already configured on both the Routers.
Anis
Yes you have to configure "ppp chap username" under dialer interface.
Silver
PPP Multilink is not been enabled...
If it is enable than use rotary group command.
" EITHER " command.
Dharmesh Purohit
Dear Dharmesh,
Can u pls explain where to enable PPP Multilink.
Dear p.bevilacqua ,
I did what u told (configure "ppp chap username" under dialer interface), but the problem is same.
Anis
178
