Webcast-Catalyst9k
Problem with a DMZ for a web server
Good evening,  I have some issue on the configuration of a Cisco 2811. I try to make a DMZ on one of the ports of the router but I can not get it from outside .I configured as follows
For int fa0/1 > DMZ
interface FastEthernet0/1
ip address 192.168.3.1 255.255.255.192
ip access-group 100 in
ip access-group 100 out
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
For Dialer0
interface Dialer0
ip ddns update hostname removed.dyndns.org
ip ddns update sdm_ddns1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname removed
ppp chap password 0 removed
ppp pap sent-username removed password 0 removed
no cdp enable
For the NAT translation
ip nat inside source static tcp 192.168.3.2 80 interface Dialer0 80
ip nat inside source static udp 192.168.3.2 80 interface Dialer0 80
ip nat inside source list 100 interface Dialer0 overload
For the acl
access-list 100 remark GVI
access-list 100 permit ip 0.0.0.2 255.255.255.192 any
access-list 100 permit tcp 0.0.0.2 255.255.255.192 any
access-list 100 permit udp 0.0.0.2 255.255.255.192 any
access-list 100 permit tcp any any eq www
Ip http server is off . With a port scan on wan interface ,the port seems open. Where am I doing wrong?Can someone help me?thanks in advance
435
