10-03-2010 11:57 PM
We’re using Cisco Router 2851 with 150 licenses to setup AnyConnect VPN SSL connection. We setup VPN SSL for Windows connection successfully. Our Iphone users want to use VPN SSL to connect to our system. But we met issue when install package for iPhone.
here is information from log file on Iphone:
2010-10-01 01:46:22 GMT - The required license for this type of VPN client is not available on the headend device. Please contact your network administrator.
My question is: Can Cisco router 2851 install packages to support both Windows, iPhone(as I know ASA 5500 series can install but not sure about 2851 router)?
Thanks a lot!
10-04-2010 12:26 AM
The latest version of AnyConnect 2.5 does not support iPhone OS yet.
Here is the list of what is supported for AnyConnect version 2.5 for your reference:
http://www.cisco.com/en/US/docs/security/asa/compatibility/asa-vpn-compatibility.html#wp157434
Hope that helps.
10-04-2010 01:11 AM
Thanks for your reply. But on apple store, there was app Cisco AnyConnect for VPN SSL.
http://itunes.apple.com/us/app/cisco-anyconnect/id392790924?mt=8#
Problem is when I try to use this app on iphone, I got the information from iPhone 's log file as I mention before. I think it cause from we have not install package for iPhone. I wonder does Router 2851 allow multi packages (ex: Windows, iPhone, Mac, Linux, etc)? As I know ASA allowed this, but not sure with Cisco 2851.
Please support me.
Thanks.
10-04-2010 01:18 AM
It's currently only supported on ASA platform as per the Description from iTunes, quoted as follows:
Please note that AnyConnect for iPhone requires a Cisco Adaptive Security Appliance (ASA) running software image 8.0(3).1 or later. The ASA requires an AnyConnect Mobile license (L-ASA-AC-M-55XX=), as well as either an AnyConnect Essentials (L-ASA-AC-E-55XX=) or AnyConnect Premium Clientless SSL VPN Edition (L-ASA-AC-SSL-YYYY=) license, where XX is the last two digits of your ASA model number and YYYY is the number of simultaneous users.
10-05-2010 12:47 AM
thanks for your help.
10-18-2010 03:40 AM
Is Cisco planning ssl mobile client for IOS (routers)?
