Problem with Dialin 3G and Dialer-Watch
we want to use a backup solution with 3G and dialer watch. The main connection is on a different router. The following config on the backup router works:
version 12.4
service password-encryption
hostname backup
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200
no aaa new-model
memory-size iomem 5
dot11 syslog
ip cef
no ip bootp server
no ip domain lookup
ip domain name bshg.com
no ipv6 cef
chat-script gsm "" "ATDT*99*1#" TIMEOUT 30 "CONNECT"
archive
log config
  hidekeys
crypto isakmp keepalive 60 periodic
crypto ipsec client ezvpn client
connect acl 101
group xxx key xxx
mode network-extension
peer xxx
acl 101
xauth userid mode interactive
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description LAN
ip address 172.1.1.34 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
speed 100
full-duplex
crypto ipsec client ezvpn client inside
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Cellular0/1/0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer string gsm
dialer watch-group 1
async mode interactive
ppp chap hostname x
ppp chap password x
ppp ipcp dns request
interface Vlan1
no ip address
interface Dialer1
no ip address
no cdp enable
router eigrp 1
redistribute static
passive-interface default
no passive-interface FastEthernet0/1
network 172.1.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 cellular 0/1/0
ip route 192.168.113.0 255.255.255.0 172.1.1.33
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
logging source-interface FastEthernet0/1
access-list 101 permit ip 192.168.113.0 0.0.0.255 any
dialer watch-list 1 ip 10.1.0.0 255.255.0.0
no cdp run
control-plane
line con 0
line aux 0
line 0/1/0
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
speed 384000
line vty 0 4
login local
end
BUT
the Cellular Interface comes up without any reason, watched route is up.
*Jun  2 10:10:21.815: DDR: Dialer Watch: watch-group = 1
*Jun  2 10:10:21.815: DDR:        network 10.1.0.0/255.255.0.0 UP,
*Jun  2 10:10:21.815: DDR:        primary UP
*Jun  2 10:11:37.651: Ce0/1/0 DDR: place call
*Jun  2 10:11:37.651: Ce0/1/0 DDR: Dialing cause ip (s=172.1.1.34, d=10.1.0.17)
*Jun  2 10:11:37.651: Ce0/1/0 DDR: Attempting to dial gsm
*Jun  2 10:11:37.651: CHAT0/1/0: Attempting async line dialer script
*Jun  2 10:11:37.651: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
*Jun  2 10:11:37.651: CHAT0/1/0: process started
*Jun  2 10:11:37.651: CHAT0/1/0: Asserting DTR
*Jun  2 10:11:37.651: CHAT0/1/0: Chat script gsm started
*Jun  2 10:11:37.695: CHAT0/1/0: Chat script gsm finished, status = Success
*Jun  2 10:11:39.831: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
*Jun  2 10:11:39.831: Ce0/1/0 DDR: Dialer statechange to up
*Jun  2 10:11:39.831: Ce0/1/0 DDR: Dialer Watch: resetting call in progress
*Jun  2 10:11:39.831: Ce0/1/0 DDR: Dialer call has been placed
*Jun  2 10:11:41.595: Ce0/1/0 DDR: dialer protocol up
Want can I do to prevent this without using dialer group for interesting traffic?
Thanks for help.
Klaus
1608
